-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Dash Electronics Fan part number? (https://landroverforums.com/forum/discovery-ii-18/dash-electronics-fan-part-number-35701/)
ShortTom Nov 14, 2010 07:32 PM
Ok didn't want to resurrect an old thread, but here's the reference if you want to look it over.
https://landroverforums.com/forum/sh...ght=noise+dash
There's a small fan on the left side of the dash that's making a significant amount of noise and since I no longer have the amigos (blessed blank dash-ness) I want to get it fixed.
Problem is, the Rover dealership guy thinks I'm nuts. Can't find any sort of "fan" behind the dash. The RAVE didn't help much either.
What is the "official" name of this thing? Or better yet anybody have a part number?
Mucho gracias!
Spike555 Nov 14, 2010 08:40 PM
Take it out.
Take it to Radio Shack.
Buy new fan.
Put new fan back in dash.
bosshogt Nov 14, 2010 10:02 PM
I think this is the part you are looking for. Its a Mini computer fan made by Denso. Only $30 on eBay not too bad.
http://cgi.ebay.com/ebaymotors/Land-...item20acc9320f
lordmorpheus Nov 14, 2010 11:03 PM
It is the inside air temperature sensor. As best I can tell from the picture in RAVE (Air Conditioning, repairs, sensor - air temperature) the Ebay link looks like the right part. I don't have a part number, but the LR parts guys should be able to find it by the proper name.
ShortTom Nov 15, 2010 06:51 AM
Originally Posted by Spike555 (Post 208890)
Take it out.
Buy new fan.
You've got a way with words Spike. Can I just stop after step 1 though? :p
Ah, very good. Thanks for the linky.
AND, I'll try that too and see if the LR guys can get a little smarter about this...I'm not against buying AM parts but I just want to be sure it'll fit so I'll get the OEM part # and post it here.
ShortTom Nov 15, 2010 08:37 AM
Ok here's the details of this part:
It is called an "in-car temperature sensor":
- Rave manual section 76.46.38.
- Part number JTF100290
- Price: $139.82
Pretty pricey. I'm gonna try to clean mine then maybe go the used route. Or try the radio shack method though I'm not sure how the "sensor" part of it would work.
And here's a pic of the location/part:
http://www.discovery2.co.uk/images/links/sensor.JPG
monkey9871 Oct 18, 2013 02:24 PM
how do i get to the in car temperature sensor to change it
suprainhabit Oct 19, 2013 04:46 PM
3 Attachment(s)
Remove the upper instrument binnacle, then the upper steering column cover. Then the blank covering the hole where the headlamp leveling switch would have been, then the mirror switch, then the base plate that all of that sits on. Drop the fuse panel cover. You'll need fairly short phillips to get to the two screws that hold the switch in place from behind. I took mine out today and took it apart and cleaned it. It was pretty gross in there. Not super hard to do, but not having small hands didn't help, either. I can hear mine working now, most likely because i removed all of the nastiness that was dampening the noise.
Attachment 18510
Attachment 18511
Attachment 18512
