Dash lights with key on engine off?
Old Jan 31, 2010 | 10:28 PM
hayabusarider's Avatar
Default Dash lights with key on engine off?
I just bought a 2001 Discovery and have a question. What lights should be on when the key is on and the engine is off? I think some of my lights are burnt out/removed. Thanks for the help.
And extra question. Does anyone know if a Snap-on scanner will be able to read ABS codes, cause my buddy has one. Thanks again.
Old Jan 31, 2010 | 10:47 PM
03discoman's Avatar
check engine, battery, srs?
Old Feb 1, 2010 | 07:41 AM
d2luvr's Avatar
Here is what I get with the key in position 1 (run) before starting:
Old Feb 1, 2010 | 07:57 AM
lipadj46's Avatar
No I do not believe so. Let us know if it does.
Old Feb 1, 2010 | 08:52 AM
hilltoppersx's Avatar
FYI the top model Snap On YA 3160 will read ABS codes... on GM, FORD and CHRYSLER cehicles 96 and up... that is a $330 scanner. You can rent an ABS amigo from one of our forum members see the HOW TO section
Old Feb 1, 2010 | 12:36 PM
Great D2luvr, that is exactually what I need. Apparently they all work except the 3 amigos, lol. Im sure they "accidentally" went out on the previous owner. Now I have another project.
And by the way, this site is great. I've read all the How To's. Im sure fixing the 3 amigo's won't be a problem. I've already fixed both blowers cause of a dead fuse block thanks to this site.
I hope the Snap-on scanner will read the ABS codes, my buddy owns a transmission shop and has a new one. If so, that will help. If not, I'll look into renting one from a member.
And if anyone needs help on fixing an E46 bmw, just let me know. I just thought they had electrical problems, LOL.
grandkodiak
Apr 23, 2013 06:44 PM
barsa
Jan 6, 2011 06:41 PM
Doral300sc
Feb 6, 2010 03:59 PM
andylad75
Sep 27, 2009 03:39 PM
scottvaughan
May 31, 2006 04:33 AM
