Dash lights off when headlights on...sometimes
Hey guys, my 2003 Disco 2 has an issue that I'm unable to figure out. Sometimes when I turn my headlights on, my dash lights go off as well as the gear shifter indicator lights. If I turn the headlights on and off the dash lights might come on. Sometimes it works on the first try, sometimes not after like 20 tries. I tried replacing the headlight switch already and it does the same thing. All contacts looked fine in the connectors. My tail lights function as normal but my drivers side one does catch some water every now and then. Do you guys think it could be the dimmer switch?
I have the same issue. I found that for a while, I could turn the lights on, then back the dial up a hair and get the interior lights to come on as well. With my issue, the running lights would not turn on when the interior lights were not on. Mine has gotten worse though, and I’m having some other issues. I’m hoping to resolve some of them with a turn signal / headlight stalk from a forum member (THANK YOU EasyDoesIt), while also resolving my slow turn signal in the cold. Is that the part you replaced?
That is interesting. For about a year, in cold weather, my headlights would experience a delay when turning them on. Then the delay affected the turn signals. Then, the dash and marker lights would turn off unless I dialed the switch back a hair. I removed the switch, took it apart and cleaned the contacts. This work for about two days, did it again and got a week out of it. Purchased a used one from a low mileage Disco and the problem is gone.
Looks like I have the same problem here... although headlights, taillights etc all work, however the dash lights, shifter lights are all dead. I think it's a faulty switch in the stalk, however looking at the RAVE manual... it looks like you need to pull the steering wheel - my question is do I have to? Someone here said 5 min job, so sounds like I don't have to.
Appreciate any help.
