-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   detroit locker (https://landroverforums.com/forum/discovery-ii-18/detroit-locker-31599/)
05gixxer Jun 5, 2010 01:57 PM
detroit locker
Can you run a detroit locker in the rear and keep the traction control in the front .
Disco Mike Jun 5, 2010 04:53 PM
Sure, the ETC will not have to work as hard. Make sure if you install a Detroit that you install H.D. axles are you'll break your factory shafts.
By the way, I run a rear Detroit and a front T.T. and that basically shuts the ETC completely, and crawls like a mountain goat.
dcaven Jul 19, 2017 07:15 PM
Which heavy duty half shafts do you recommend for a detroit rear setup in a Discovery II?
Thanks.
Alex_M Jul 20, 2017 01:01 AM
Mike isn't really around any more. I would say run the stock axles till you break one, then upgrade. I think the strength of the factory axles is underrated. Shade Tree has a Chevy 5.3 in his and runs a Detroit with 4.11s on stock axles. He tells me he isn't afraid of the skinny pedal, either.
yubert Jul 20, 2017 04:29 AM
I don't think it's necessary to upgrade the D2 axles because the rear axles are stronger than the D1, RRC stock axles. I understand LR made them stronger because they were concerned ETC would add additional stress. I have pictures showing the difference is diameter between the D2 and D1 but can't find it.
Also, the new Detroits don't shock load as hard as the older ones, when they engage. With that said, I upgraded my front and rear axles with Ashcroft axles because money grows on trees.
dcaven Jul 20, 2017 08:18 AM
Yubert: I have quickly noticed how expensive the Ashcroft stuff is. Has me scared straight. I'm upgrading to a CDL and want to add a Detroit rear and Truetrac front at the same time but the axle upgrade parts are about $700. Yikes!
Mskembo Jul 20, 2017 05:10 PM
Call up Great Basin Rovers in Salt Lake Utah. They can hook you up.
