DI and DII Interchangeable parts???
Hey guys, I'm going to the junk yard to pull some wiper arms off a wrecked DI to put onto my 02 DII so that I can change my wiper blades like a normal human being again.
Are there any other easy to grab parts from a DI that will translate over to a DII that I should grab while I'm there? |
Light bulbs and fuses, that's about it.
The homelink fitting works from a D1 or D2, and the ashtrays/coin trays are interchangable... =)
Bummer. The only things I know of that will transfer over are wipers arms and water pump. They wanted $40 for the wiper arms (rip off)
They did have a full set of 5-16" DII rims for $225.....now to try convince the wife that a second set of rims are a neccesity :D I'll see if they throw in the ash/coin trays and all the bulbs and fuses too;) |
pretty sure the diffs are the same, but you won't want a worn out one from a junked D1.
You need to go back and buy those DI wiper arms.
http://www.roverparts.com/Parts/PRC8236.cfm |
The sunroof's are the same. The diff's are the same, just got to swap the 3&4 bolt flanges if necessary. But like okdiscoguy said don't go for the high mileage ones.
Originally Posted by Spike555
(Post 164185)
http://www.roverparts.com/Parts/PRC8236.cfm They had a DI and a DII, both have over 110K and were pretty thrashed, I think I'll stay away pulling too much from either truck. Those wheels are very tempting though... Thanks for your input guys. |
