-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   DI Drivers door will not open from inside or outside (https://landroverforums.com/forum/discovery-ii-18/di-drivers-door-will-not-open-inside-outside-22617/)
roverohio 06-10-2009 01:46 PM
Tried everything..Need new accuator? Drivers door only...are all accuators the same on DI?
Disco Mike 06-10-2009 03:13 PM
No, each door has a different actuator.
Have you tried to pull the inner door panel back far enough so you can open the door from the inside?
okdiscoguy 06-10-2009 04:38 PM
Hold the lock up in the fully unlocked postition. If it opens, I know what you need...
roverohio 06-10-2009 10:19 PM
pullled panel back could not get open. pulled the lock up and still would not open? will try again tomorrow..
okdiscoguy 06-11-2009 08:25 AM
It is tricky, but the door panel can be remover with the door closed. Try to do it and open it from the inside of the door.
roverohio 06-11-2009 06:22 PM
anybody ever by-pass the accuator? I does not matter if the door locks just as along as I can open the door..
Joe
