DII Radio Removal
You have the right tools. Did you feel them click into place? Should be very difficult to remove the tools from the slot once they're seated without removing the radio.
With the tools in place, stick your fingers in the tape slot to get as much grip as you can and just pull hard.
Not sure about the D2, but on the D1 there are two antenna connections to the rear glass. May even be some sort of electronic amplifiers back there for the antenna. One side is FM only, the other is FM/AM. My previous owner installed an updated Sony, selected the wrong antenna, and now I can't get AM stations. So test before you button everything up.
Don't want to buy anything, plus I just ordered a bunch from AB, so I'm not going to re-pay for shipping
..... ^^THAT^^ is what I shoulda done in the first place! Too late now. The wife is out of town (Disco is her daily driver) so I've got the battery unhooked, the grille out, etc, etc, so I can install my CB and wire up my Hella's, so I'd rather not put it all back together just to pull it all apart again
Good point, I Do they go pretty far in? It felt like I was pushing them in about as deep as they could go and still couldn't get it to budge. I had assumed this would be a quick snap job to get it out...
HOLY EFF! What a PITA. I had the right idea, just wasn't getting the "tools" in straight enough. After wrestling with it for what seemed like forever, I finally found the touch to pop the brackets out of the way.
While I was in there, I popped out the HVAC controls, almost as much of a PITA as the radio. I'm going to replace the bulbs for the control switches, and install my CB radio directly above the stock radio. Hopefully in such a way that I can easily remove the radio and mount and make it look completely stock.
Thanks for the help as always gents!
