DISCO 1 OR DISCO 2 PROS AND CONS
HELLO EVERYONE I CURRENTLY OWN A 95 DISCO AND HAVE BEEN THINKING OF UPDATEING TO A SERIES 2 BUT THE SERIES 1 HAS BEEN AN EXCELLENT LAND ROVER SOMETIMES CHANGE ISN'T ALWAYS GOOD. I HAVE HEARD THE SERIES 1 IS A BETTER 4X4 THAN THE SERIES 2 IS THAT TRUE? AND WHY? I HAVE YET TO FIND A SITUATION I CANT GET OUT OF WITH THE SERIES 1. BUT THEN THERE IS THE 109 I HAVE AND IT IS LIKE A TRACTOR I BELIEVE IT IS NEARLY UNSTOPABLE I ONLY WISHED IT HAD MORE ENGINE POWER. ALL COMMENTS WILL BE APRECIATED. FREDERICH
RE: DISCO 1 OR DISCO 2 PROS AND CONS
I love my 2000 DII. As far as 4X4 goes, like mike said, series II seems to be a bit better. At the same time it has alot of gizmos and gadgets that could fail making it more prone to break down, but usually if you take care of your truck it wont be an issue. This is usually my take, a d1 is a great truck and you can throw it around a little more than a DII, but the DII could outdo the DI anytime on a tough trail. Thats my input!
Well to jump in on this one since I have both. Mike is correct about the Disco 1, my '95 will out do the '01 any day, when it comes to climbing around. It also has a softer ride than my '01 but it has 18" wheels on it, and the '95 has 16" with more tire. Now when it comes to towing my '01 does tow a trailer much better, seems to have a little more power,butit does have a littlebigger engine.It also doesn't wander as much with the trailer behind as the '95. Ultimately the decision is yours, but I like both of mine for separate reasons and uses.
