-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Disco 2 Bottle Jack not working (https://landroverforums.com/forum/discovery-ii-18/disco-2-bottle-jack-not-working-56251/)
aguison Jan 26, 2013 02:21 PM
I was finishing up my 3 Amigos repair on my 2003 D2 and getting ready to bleed the brakes... took my bottle jack from the engine compartment and to my surprise the jack doesn't work! (it doesn't want to raise up)
According to the Owner's manual, all you need to do is turn the thing at the bottom clockwise until it's tight and then start pumping
I did that and the jack would not come up. Is there anything else I should be doing?
According to some posts I read, there is a seal? that needs to be replaced and you need to fill up the jack with fluid?
As always any help is appreciated
Sincerely
Al
2003 D2
ZGPhoto Jan 26, 2013 02:29 PM
This has happened plenty, just buy another one at harbor freight or something.
aguison Jan 26, 2013 02:46 PM
They have those at Harbor Freight?
Disco Mike Jan 26, 2013 03:03 PM
No, Harbor Freight and Sears have much better bottle jacks for less money.
aguison Jan 26, 2013 03:20 PM
Thank you very much
aguison Jan 27, 2013 06:01 PM
1 Attachment(s)
Here is the bottle jack I bought from Sears
Attachment 14065
USD 17.00 2-ton capacity and fits perfectly inside the battery cover in the engine compartment. The factory tools fit the jack and work it well.
Notes:
1. However, the jack is short and does NOT raise high enough to get to the D2's jack mount points. :(
2. You will need two 2x4 pieces of wood to make it work and stow them in the back of the vehicle.
Regards
Al
ZGPhoto Jan 27, 2013 06:04 PM
Is it tall enough to reach the diffs? If so you're good.
Michael M. Koch Jan 27, 2013 07:19 PM
I found a Husky jack at Home Depot a few years back that also does the trick. And fits in the stock bottle jack location.
