Disco 2 Cuts Ignition upon reaching operating temp.
Hey all, I have a 2001 Disco II. I've been having some serious ignition problems. The ingnition simply cuts off and kills the engine about the time I reach full operating temperature. Alternator, Battery, Ignition Coils, Plug Wires, and Plugs have all tested perfect. Doesn't seem to be a problem with the charging or starting systems, because i'm not having any electrical problems (lights dimming or anything of that nature). Any ideas or stories of a similar nature would be greatly appreciated. Thanks
Originally Posted by RoverJunkie13
(Post 147912)
It sounds like it is the temperature sensor. Not the one for the gauge, but the sensor for the ecm. |
Or a crank position sensor would be a more common (to DII's) guess.
Bad crank sensor.
Replace it and all will be right with the world. |
So, what does it take to restart it, do you have a check engine light on?
Normally I would say crank sensor but they just don't shut down when hitting operating temp. |
| All times are GMT -5. The time now is 07:42 AM. |
