Disco 2 throttle body re-assembly
Has anyone had their throttle body powder coated and then needed to reassemble the dang thing. I had it powdercoated and apparently somebody forgot how to reassemble it. If need be I will buy on to dissect so I can put it back but figured somebody might have had this problem before.
Thanks in advance
Thanks in advance
I think the major pia will be the tension springs between the two white bushings. There is an inner and outer spring. The actual throttle and cruise control are relatively simple...looking that is. I'm sure it might be some trial and error and a few adult beverages and choice words to get it right. Thanks for looking out
On a bright note, at least the damn thing will be clean as new on the inside and look pretty damn good on the outside. I'm ready to get it all back together. Going with a gloss wrinkle black on all the upper stuff, black ceramic on the exhaust and heat shields and gloss black on the pulley's.
Got the throttle body back today from my powder coating guy. Got the upper n lower intake yesterday and a few pulleys. Went with a gloss wrinkle on the powder coating and will try to start assembling the throttle body tomorrow and take some pictures as I go. I think it will look good when it's all said and done. Even got the heat shields done to match the exhaust manifolds in black ceramic.
