Disco 2 wont shift out of park help!
The discovery 2 wont shift out of park but the car starts up and all the electrics work need help on what this could be. was told it was a sensor but don't know for sure.:eek:
RE: Disco 2 wont shift out of park help!
If the rear window heater and 3rd brake light wires touch you
will blow a fuse to the brake lights, check this. It could be the brake light switch. Just make sure that you have brake lights if you dont this is it. |
Is your Disco still broken?
No it's fixed turns out it was a faulty sensor with the brakes not releasing the shift to move out of park Land rover fixed it for 40 bucks. Thanks for asking Landzu.;)
I'am glad it was a cheap fix (for LR).
I would like to know more, as a lot of the places I travel have no one that can or will work on a LR. I may need to add that part to my part bend. Thanks Mike |
| All times are GMT -5. The time now is 04:59 AM. |
