Disco Headlights, and wheel trim plastic!
my 03 disco has no mechanical problems with 93k miles, but a few cosmetic problems that really annoy me. both head lights fog with condesation when its even slightly humid, and the wheel plastic fenders have faded from dark smooth black, to ruff smoke grey. dose anyone know a easy way to fix this without spending alot of money? or has anyone had these problems and got them fixed?
Its usally worse then this,
usally the whole headlight.
both headlights do this, right
is worse, do you think they
arent fitted correctly?
the right side is worse the the left, the tires and fenders
used to be the same color.
RE: Disco Headlights, and wheel trim plastic!
The dealer put 'drain tubes' into the bottom of both of my headlights which cured my water problem....check here for the wheel arches.....
https://landroverforums.com/m_61006/tm.htm
-aaron
2003 Disco SE7
-aaron
2003 Disco SE7
If you want to replace, then check out Rover Connection...they have all six new as a set for $400..
http://www.roverconnection.com/Disco...rch_Flare.html
-aaron
-aaron
bcolins
12-11-2013 01:26 PM
skatelove303
07-20-2010 06:42 PM
DiscoWest
09-23-2009 10:15 AM
Barron2032
01-07-2009 11:12 PM
