Disco II Winch Bumper
Hi All,
Here are a few pictures (renderings)of my winch bumper I am going to build for my 99DII. I would appreciate any comments on the design. You will not have to cut the grill out to fit most any winch. Thanks rhinocat [IMG]local://upfiles/5149/8197317DB9014BAABBDE09DB45DAD562.jpg[/IMG] [IMG]local://upfiles/5149/1D564B230BC949DFA7DCAD76010F5266.jpg[/IMG] [IMG]local://upfiles/5149/17D7413BA12B41E88BD2F3C4BDC2405A.jpg[/IMG] |
RE: Disco II Winch Bumper
If you will send me your e-mail address, I will send you pictures of mine that I built.
What sort of material will you be using? Are you removing the crush cans? Are you going to brace those side wings? Mike |
Rhinocat,
Where did you go??? Mike |
Do you have these with dim's? Did you design it? If so can you e-mail mea copy, I have access to all of the autocad systems as well as pro engineer. The only thingI might changeis to make it taller ( to cover washer fluid tank) andmake sure youinstall tabs on the bottom to install a skid plate if you want to later.It'd suck to find out that you want a skid plate after you've already powder-coated it.
Mike, I'd like to see yourstoo. My e-mail is tailchaser0527@hotmail.com . I'm trying to find a lot of good ideas to combine before I make my own.
Sent you some pictures. Don't consider putting a skid plate on the front of a D2, they tend to overheat the engine when out on the trail on a hot day.
Mike |
| All times are GMT -5. The time now is 04:54 AM. |
