Discovery Camping
Old 08-01-2018, 10:41 AM
LR03NJ's Avatar
Sounds like a great outing. Yes, sometimes you have to push yourself a little beyond your comfort zone...to achieve any degree of confidence in yourself and rover. Believe me, first time I went wheeling with the Ohio LR club...it was a little beyond what I thought the rover was capable of. They had mentioned in advance, that this outing would be for rovers with lockers, lift, working CDL, working traction control, winch and tires over 33". Was good in three departments, winch, CDL and lift...lol. But, all's well that end's well.
Thanks, for sharing and your rig is really turning out nice.
Brian.
Heart pounding, YES! What you mentioned was all true. Before we left I was comparing my lifted truck with new tires which I smashed both front and rear bumper here in NJ from off roading. But the trip was 5 hours away and my other truck (silver) have no CDL but no amigos. I would like to test how the grey would feel like hauling with tons of camping equipment plus a little light off roading which turned to be harder, LOL! I did measure the difference between stock and lifted from ground to the differential. Though the other looked taller the clearance of differential to ground is only 1-1/4 which I know could be a lot in real situation but I'll suffer the 5 hour drive to the place. LOL! The suspension made it higher as well. If only I have better tires, I would be able to go through with no problem since I got out of the situation with flat tire. Well, I need more wheeling to learn. hehehe
Old 08-01-2018, 10:50 AM
LR03NJ's Avatar
Originally Posted by wjsj69
I'd be bushed just unpacking and repacking all that gear! Plus kids, wife and dogs?!? Wow! The wheeling would be the most relaxing part of the trip!!
True, On the day we left which was supposed to be 4:30am, placing all the gear on the hitch carrier, everything was like a swing, swinging side ways so we had some delays because I had to run to the shop and had two nuts welded and secure the carrier.
Freshly welded same day we left.
Old 08-01-2018, 11:09 AM
LR03NJ's Avatar
Originally Posted by Richard Gallant
Wow that is one loaded truck, and with good stuff for comfort.
Good on going out with what are basically street tires, and flats happen even to guys with nice off road tires.
One piece of hindsight advice, when you get stuck or cannot move, take a second and check your gearing, and the CDL. I have done it myself thought I was in low and was sitting in high and not locked. Annoying but not the end of the world.
EXACTLY! EXACTLY! Thats what happened. No matter how much rev I did, it wont move. The guys were thinking that the trans might got a bad hit. A bunch of them tried to lift the rear just to keep it moving but nothing happened. Until, the trail leader came and checked the shifter and moved it to LOW/CDL and the truck moved with no hesitation at all and got me out. Youre right about that situation.
Old 08-01-2018, 11:23 AM
LR03NJ's Avatar
Not everything went as planned but all who went to the Muddy Chef Challenge was not spared by the bad weather. Still at the end, we all had a blast.
Old 08-01-2018, 12:10 PM
Received 1,131 Likes on 781 Posts
Those pictures are why I sleep in my Disco but then Pacific Northwest most of the year it rains.
Old 08-01-2018, 03:30 PM
The Deputy's Avatar
Received 1,160 Likes on 836 Posts
Wow, talk about being drenched. Yep, sleeping high and dry inside the rover for me too.
Brian.
Old 08-01-2018, 04:50 PM
Saturnine's Avatar
I would totally opt for camping inside but the wifey and I have a 60lb dog.. Can't fit all 3 in the back with the rear seats removed
Old 08-02-2018, 09:52 AM
Goodness. What a great build. Nice job.
LR03NJ (08-02-2018)
Old 08-02-2018, 12:23 PM
ahab's Avatar
I'm speechless on every level. Well done, Jerry.
LR03NJ (08-02-2018)
Old 08-02-2018, 12:27 PM
LR03NJ's Avatar
Default Random Off roading pictures of event
Got some pictures taken by other Rover people that day during the flat tire mishap. LOL!
The following 2 users liked this post by LR03NJ:
No Doubt (06-25-2019), Richard Gallant (08-02-2018)
Quick Reply: Discovery Camping
