Discovery Mileage
RE: Discovery Mileage
It depends on how well it was taken care of and what type of driving it was used for. Check for anything obvious, such as coolant leaks misfires, etc...
No one on this forum will really be able to help unless we could have the Disco right in front of us. Use your best judgment. That means research as much as possible and search the forums!
Cheers,
Pete
Cheers,
Pete
Well 134,000 miles is not considered high miles anymore. You need to be over 200k to say that.
But with that being said, these trucks will last well into the 200k range and some have reported over 300,000 miles.
Just so you know you MUST use premium gas, LR's require it, not recommend but require.
The front driveshaft must be rebuilt using greasable u-joints.
Any more questions the people on here are always willing to help.
Preventative maintenance is the best method to avoid catastrophic problems later. Most car owners are gas-and-go types. Even with a used Rover with over 100K miles, you can fix it up and expect it to last a long time. Don't let small problems become big repairs. I put my Rover on a lift at least once a month to check for leaks, loose equipment, and anything else suspect. Finding small issues now means cheaper fixes and more peace of mind.
Cheers,
Pete
Cheers,
Pete
my 3k$ 75kmile Disco has given nothing but trouble
why only good gas? the CR is only 9.35, and the advance is not agressive, i have no ping w/87
we MUST run 93 in the 10.5:1 25psi boosted monster in the garage, i feel the rover can do w/o, esp if you pull about 3*advance
maybe i should tighten the squish. bump the CR to 10:1, add a litle swirl, and groove the head, 87 would do it then for sure
You need to run premium not because of the compression ratio but because there is no EGR to cool the cylinder chambers and because of that fact the combusyion temps are higher when running lower octane gas and it bakes the oil inside the engine thus causing excessive sludge build up.
So by running 87 octane gas you are costing yourself money and starting a huge headache.
Ever notice that a not well cared for Disco has excessive engine sludge? Why? Because the owner went cheap with his $45,000 truck and ran the wrong gas.
You get what you put in, cheap in and trouble out. Its a $45,000 truck and needs to be treated as such.
Use the right parts/gas and you will not have so much trouble, sorry but thats just the way it is.
The Rover engine is a very over-square design, meaning the pistons are much wider in diameter than the length of the stroke (94mm x 71mm). Although many newer engines (especially high revving Japanese cars) have over-square engines, the Rover engine was not originally designed for these specs. I assume Rover ran into some problems running the 9.35:1 compression and decided to use premium instead of lowering the compression or changing the bore or stroke. All things considered, I wish they offered a diesel here instead.
Cheers,
Pete
Cheers,
Pete
