-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Does the rear diff leak often? (https://landroverforums.com/forum/discovery-ii-18/does-rear-diff-leak-often-40602/)
discoboy May 9, 2011 12:42 AM
Pulling behind the D2 on Saturday, I noted the bottom of the rear diff was wet. Inspected the rear differential and saw fluid leaking from pinion seal. Is this pretty common? Another leak to add to my problems as well as my ticking engine. Gotta love these trucks.
Bundu May 9, 2011 05:23 AM
No it's not normal or common.
sloan74 May 9, 2011 07:53 AM
Not common.
How much leaking we talking here?
tweakrover May 9, 2011 10:53 AM
Check to make sure you're axle breathers are not clogged
DarylJ May 9, 2011 12:20 PM
This is absolutely critical advice.
I have a friend who has done axle seals 3 times before he realized that his breather was pinched off when the idiots at the dealership put the utility body on his pickup.
If it's clogged, it's not going to prevent you from having to replace the seal. But it will prevent you from having to KEEP replacing the seal.
photocrimes May 9, 2011 03:40 PM
Yep, check the vents. Diffs are one thing that seem to hold fluid on the Rover.
hunter May 9, 2011 05:57 PM
Engine ticking
Disco boy - didn't you take your rover to Livermore to get the ticking fixed?
Best,
Dave
Spike555 May 9, 2011 09:25 PM
What these guys said, clogged axle breather, check that first.
When I first got my truck the front seal on the rear diff leaked, replaced the axle breather and the leak stopped.
That was 4 years ago.
