Doing my lift tonight and need help
I can't say for sure, but an "inch" lower does not sound right at all. I have a 2" MD Terrafirma kit and added the D1 perch plates in the rear and my *** end is approx. 3/4" higher than the front.
Okay then you can put like i said the D I spring perch or add a 1 inch spacer to the rear or add both your truck. It has to be your preference you drive any 3 of those options are safe as long as performed correctly. Good luck let us know what you decide to do or if you have any other questions. All ways can vary in height when you add pounds..... so depends on what you haul?
