Door lock/actuator ??? Door key won't turn cylinder
I put the key into the outer door lock and is does not budge once it
It placed in cylinder/outer door lock. Do I need to replace the actuator or something else? The door will lock from the inside of the car and will lock when I press the door Lock mechanism in the dashboard area. This is the drivers side door lock. Thanks! Can anyone recommend a good place to find a repalcement Lock/actuator if that is the case? Thanks! |
Sounds like you need a door lock pin.
Some guys on dweb have dabbed them using a large nail. Can't remember what size though. Check out discoweb. |
Here is one for $20
http://wheeltrendz.com/LAND-ROVER-FRONT-LEFT-LH-DRIVER-DOOR-HANDLE-PIN-DISCOVERY-II-CXB103030H |
Fixed mine
Pulled my handle out found at the end of the cylinder the last tumbler was broken and in the way not allowing the key all the way in. I pulled it out of the cylinder. Now working
Originally Posted by abran
(Post 492763)
Some guys on dweb have dabbed them using a large nail. Can't remember what size though. Check out discoweb. would you be able to find a link or help me to find the page on that site? i am having the same problem now and I couldnt find any information anywhere except your post:) |
Not exactly what you were looking for, but should help:
2004 - Door Actuator - Land Rover Forums : Land Rover and Range Rover Forum Take the broken pin to the hardware store and match up a nail that has the same circumference. Then modify it to match the broken pin. Or, Dish out $85 for the Cadillac of door pins: http://www.jewellamberoil.com/sales/...roducts_id=297 |
