Door Lock Questions
I actually have 2 questions about the locks.
1. Should unlocking the passenger door or rear cargo door disarm the alarm system like the driver's door does? If I unlock my driver door, all the doors unlock and the alarm disarms. If I unlock the passenger door, none of the other doors unlock and the alarm sounds if i open the door meaning it is not disarming. I have not replaced the remote for the keyless entry system so I'm referring to unlocking the doors with the key. 2. I can't get my key in the lock of rear cargo door. It goes in about 1/8 inch then stops like it hits something. Anyone else have a problem like this or even heard of this. Thanks for the help Tom |
RE: Door Lock Questions
1. Mine does the same thing. Its a pain. I do not know if it is normal or not.
2. Try lubing the lock. Take silicon spray and stick the straw into the lock and really soak it, then try the key. Repeat if necassary. Also pop the LR logo off the handle and lube that up as well. It will stick if you dont and you will not beable to open the door. I have to do mine once a week because I work at a gravel company and the handle gets full of dust. |
1, Thats how its made.
| All times are GMT -5. The time now is 05:18 AM. |
