Door Locks
Door Locks
I have a 2001 Disco II with 115K miles - so ite relatively older...
first started with my rear door locks not working - would not open with the remote key opener - now it is the driver side door that cannot be opened with the remote key -
I haev checked the fuse #1 and it looks good -
has anyone come across this problem - and how do you fix it ?
Thanks
Kevin - Dallas, TX
Thanks
Kevin - Dallas, TX
door panel removal tool is the best to prevent breaking the little plastic retainers but as long as your careful you can usually pry the bottom ones loose and then give the panel a quick jerk without breaking to many if any at all (its ok to break a couple as there are usually about 2 or 3 times more than are truly needed) just be sure all screws are removed first!!!
