Drive belt routing for D1, need help
Does anybody have a pictureof the accessory drive belt routing for a 1998 D1? I could not find a sticker or image of it in either the engine bay or owners manual.See if this seems right: the way mine is routed there isn't much belt contact with the alternator.I've heard it's easy to mix it up.Being a new owner I don't have a baseline.
Any help appreciated. Thank you, much |
RE: Drive belt routing for D1, need help
See if this helps Mark.
http://www.roverparts.com/TechTips/s...g_defender.cfm |
Thanks much. Major help. It's confirmed now, the previous owner (or mech) put the belt on incorrectly. I think the charging problem I've been having all along is because the belt didn't go around the alt properly. DOHH!
| All times are GMT -5. The time now is 03:40 AM. |
