Drive shaft fix
I keep seeing "rebuild your drive shaft" , but i never see fix the main issue that causes the drives shaft to fail.. #1... air conditioning drain draining on drive shaft. When they replaced my engine they re plumed mine so it does not drain on the shaft anymore. I will see if i can get pick or a writeup on how they do it at my rover shop.
Thanks Chris |
While that is one issue, the lack of ability to grease frequently is also a big player.
It's the bigger player, not greasing them, that is.
This thread gives me an idea- build a quarter-round shield to cover the t-case end if the front d/s. Protect it from a/c drip and converter heat. But it would leave enough open to be able to grease it.
Won't work, the u-joints will still fail when not being lubricated , just from their own internally generated heat.
why arent these more talked about? this is what i have after my driveshaft broke.
thats a start
Originally Posted by Dayton Atworth
(Post 303651)
Originally Posted by kenk
(Post 303547)
Sure you would still need a new driveshaft, but at considerable less cost than that AND a transmission. |
Didn't we already have a recent post from someone who actually builds protection loops? See https://landroverforums.com/forum/mo...riveshaft+loop
| All times are GMT -5. The time now is 05:23 AM. |
