Drive Shaft Grease
RAVE says to use the following for general greasing. Is it what to use on the u-joints?
Multipurpose Lithium Base Grease N.L.G.I. consistency No. 2. Thanks, Dave |
Yeah, NLGI #2 works fine for u-joints.
Everyone has their own preference for what brand/type. I use Castrol Pyroplex Blue: http://www.castrol.com/castrol/secti...tentId=7022499 |
I use Green Grease.
http://www.tractorsupply.com/vehicle...-ounce-8010059 |
+1 i use green grease as well
Thanks, guys. Appreciate the feedback.
And grease your u-joints 2 times a year and the slip shaft on each drive shaft once a year.
Have you already had your front drive shaft joints replaced to prevent failing? |
Thanks, Mike. Yes, I have had them replaced. I only put about 8-10K a year on the vehicle, but change the oil every few months, regardless of mileage. I want to get into the habit of lubricating the u-joints myself, as well as this summer when I am in the eastern Sierra and Nevada.
Thanks, Dave |
The service interval for u-joints under normal use is every 5,000 miles or 3 months.
Originally Posted by antichrist
(Post 224911)
How should I go about putting on the grease? Take off the front right wheel? Or just climb under and rub it on.
| All times are GMT -5. The time now is 01:20 AM. |
