Drivers Side Signal Light Problem
I'm having a familiar issue like others. My drivers signal works fine, except when my headlights are switched on.
I've change the light insert and bulbs. No effect. Then I saw this burn mark. Do you think I should but the connector and install a new one?
Thanks
Sean
Thanks
Sean
That looks fairly important. I would certainly say it needs fixing.
I would try and find a new socket and connector with pigtail if possible, but from experience it can be very difficult, as they tend to be LR-unique. You may have better luck with a new socket with integrated pigtail and a generic 3-pin connector.
Thx
Sean
I would use heat shrink butt connectors. No need for tape, although I suppose you could do it anyway.
Best way to connect them is to twist the wires together and solder them, and cover with heat shrink.
