-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Dual Battery/Alternator question (https://landroverforums.com/forum/discovery-ii-18/dual-battery-alternator-question-61924/)
primussucks 09-20-2013 08:24 AM
Originally Posted by Daedrix (Post 421582)
Make one like i did. I run them in PARALLEL. I run a yellow top and a blue top. They are always connected in parallel and im using the stock alternator.
https://fbcdn-sphotos-b-a.akamaihd.n...35329397_n.jpg
https://fbcdn-sphotos-h-a.akamaihd.n...65306007_o.jpg
https://fbcdn-sphotos-f-a.akamaihd.n...54958120_o.jpg
Nice... I'd be a little scared for those screws though. A little wiggling from the battery and they could go right in the side..
How are you securing them from the top? did you put rubber mat on the bottom to absorb some of the vibration (and prolong the life of the batteries)?
Daedrix 09-20-2013 09:28 AM
Those pic are from when i was putting the setup together, the final product looks different. The screw are no threat partially because the battery has rounded edges and the is little to no wiggle room. I did add a rubber mat under the batteries and i secure them with a simple tie down strap like this:
http://creekcompany.com/images/P/811-a-lr.jpg
primussucks 09-20-2013 11:14 AM
Do you have pics of what the base/underneath of the boxes looks like? did you just build a foot to account for the curve of the wheel well?
Daedrix 09-20-2013 11:56 AM
There is nothing underneath the boxes, and no foot. Forward looking aft, the top of the boxes rests on the curve of the wheel well(rubber strip in between so no metal to metal chafing), the left side is supported by the "L" bracket, and the bottom is secured with screws to the body of the vehicle. It might not look like it but it is really secure and budge.
https://fbcdn-sphotos-h-a.akamaihd.n...65306007_n.jpg
primussucks 09-20-2013 01:10 PM
Thanks..
Maybe I'm missing something here... But the height different between the most forward portion of the box, and the rear of the box is about 3". The curve of the wheel well..
Do your batteries sit on an incline?
grandkodiak 09-20-2013 02:48 PM
Throw the battery in the back, and keep it as a jump box or portable power source... rig up a small solar trickle charger and toss the panel on the rear bumper or roof or in the window inside :)
dusty1 09-20-2013 04:17 PM
Originally Posted by primussucks (Post 421699)
Thanks..
the box that i fabbed is raised at the front to make it level to the wheel well contact point. I used 2" angle iron self tapped and bolted towards head light.
Charlie_V 09-21-2013 08:31 AM
I guess the point was that I already have the battery, it has been used for a total of 15 minutes, and I like to tinker. I'd seen the Columbia Overland tray and it looks like something even I could fab up.
The isolator and relay setup is a great idea. I have been circling the idea of a TJM bumper (sold in San Antonio... Not a tremendous distance from home) and a couple of lights on the front. Also, one of the things that my LRover lacks that most of my vehicles have is always on plugs for charging a laptop, cell phones, and a mobile printer that I always have with me. As is, I can only do that with the ignition on.
Great comments. Thanks! Once again, this forum is the best balance of helpful and informative for Rover owners.
Best,
Charlie V
