Electrical Issue
I would replace the alternator.
It may be overcharging.
I bet your battery is fried from overcharge and I would replace the alternator and the battery.
actually I would do this:
1) Pull terminals from batter and clean them.
2) Replace the battery.
3) Replace the alternator.
3a) Check air conditioning compressor connection. Put an ohm meter across A/C clutch and check for low resistance or short.
4) Clear the codes.
5) run and check for new codes.
Your codes are:
Engine Code: p1536
Land Rover Engine Code: P1536 = Air conditioning compressor request range/performance ATC compressor clutch relay open circuit.
Click to Process more Land Rover Engine Codes here
Engine Code: p0560
Land Rover Engine Code: P0560 = System Voltage Malfunction
4) Clear the codes.
Your codes are:
Engine Code: p1536
Engine Code: p0560
