Electrical Issue
#22
On another side note, the vehicle cranks just fine so the battery is ok.
Compelete list of codes before I cleared and re started the vehicle were :
P1668 - which is the security code
P0560 - system voltage error
P1536 - AC circuit error
P0340 - camshaft error
The vehicle displays all lights when in "run" on the ignition, it turns over just fine and the check engine lights turns off while cranking the vehicle. comes back on when the vehicle fails to start.
After clearing the codes, P0560 and P1536 stayed on
#23
#25
#26
Well, mine is a 2001 and hers is a 2002. They both looks identical. Tomorrow I will have the permanent replacement to install and I'll let it sit for some time and hopefully it will sync. If the vehicle still turns over without running I'll take a look at the crank sensor.
And thank you very much for walking me through this.
#27
#28
#29
#30
