Engine Code?
Engine Code?
I managed to track down some Magnacore wires over here - Great!
160 AUD - not as bad as what I thought. (140 USD)
But they want:
I'm at a loss as to the engine code or where to find it.
help!
________
Use I Inhale Iolite Vaporizer Review
But they want:
- year OK
- model OK
- chassis model
- engine code
help!
________
http://www.magnecor.com/magnecor1/files/catalog.pdf
If you have a 94 it is different. I show 80196 as the part number for the 8MM. The part number listed above is for 7MM on a 96 & up distributorless ignition
PS, not sure if they will ship to you, but they are $74 here..
http://www.apexperformance.net/CartGenie/prod-1158.htm
Yes yes.. you are correct. swing and a miss, will edit my post as not to confuse
Not changing the rotor for now.
The truck is running great - compared to recent history! just using enough fuel for two.
The existing leads are cheap & nasty and the plug covers are cracked.
no they won't ship to Australia.
I was just after the info they asked for, I'll let them work out the part number, thanks.
Does anyone know what the engine code is or where I can find it?
________
Class action settlement
________
DiscoBenjamin
10-14-2011 05:53 PM
