Engine code P1536
Checked codes today using a friend's tester and came up with:
P1536 - Air conditioning compressor request range/performance ATC compressor clutch relay open circuit I posted the other day saying that my AC didn't seem to be blowing cold, though I had the windows open so perhaps I confused the climate control. Also, I did disconnect the battery this weekend so I could clean the terminal posts. That being said, are there any obvious actions to take regarding this code? Thanks, DRW |
Check the refrigerant level in the a/c system.
I dont think the a/c will throw a code, but then I've been wrong before. |
Thanks, I'll check!
DRW |
| All times are GMT -5. The time now is 10:01 AM. |
