Engine issues, rough idle, bad o2's..
Here is whats recently been replaced:
Passenger front and rear 02's. Spark plugs (E3 Spark Plugs E3.48 Automotive, Truck, Van and SUV OEM Replacement Spark Plug , Pack of 1 AMAZON) Waiting on spark pug wires. CODE ISSUES: P0130: O2 Sensor Circuit Malfunction (Bank 1 Sensor 1) P0300:Random/Multiple Cylinder Misfire Detected (Obviously because multiple misfires) P0301:Cylinder 1 Misfire Detected P0161:O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2) P0305:Cylinder 5 Misfire Detected P0307:Cylinder 7 Misfire Detected P1300:Boost Calibration Fault (I don't understand this one) Every once in a while I get these: P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1) P1129 Downstream Heated O2 Sensors Swapped P0171 Fuel Trim System Lean (Bank 1) P0160 O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2) What does everyone think? I will replace the plug wires when they arrive. I think the coil might be going bad but cylinder 3 isn't having any issues. |
have you tried reset any of these codes after installing the new O2 sensors?
Been down this road , trust me on this use only landrover 02 sensors ,if not u will have a rough ideal . And do the two of them .
Install your new 02's, plugs and wires, then clear the codes and let us know what shows up still, if anything. You are on the right track.
Originally Posted by drowssap
(Post 338219)
Originally Posted by SWAINROVER
(Post 338232)
Originally Posted by Disco Mike
(Post 338245)
Thank you all for your time. |
Definitely try torching the pipe, it'll expand the metal and make it easier. Also, the longer the handle on the socket you use, the more torque you're using.
It looks like all of your misfires are on the "odd" bank. I'll bet replacing your o2 sensors helps that.
Originally Posted by oilspotLR
(Post 338254)
Any advice on how to get the drivers o2 before the cat out?
Originally Posted by ZGPhoto
(Post 338255)
Originally Posted by jafir
(Post 338257)
you can try heat but that connection has already been heated and cooled a million times just buy the converter exhaust.
I would soak it in SeaFoam Deep Keep and put i big ass box wrench on it or make a full commitment and cut the wires off and use a socket and breaker bar. Also just because you bought the 02 sensors from Atlantic British does not meen they will work. There are a few old post from people who went thru two or three sets of AB 02sensors before getting there money back, there is a reason they are only 69.00. |
| All times are GMT -5. The time now is 08:50 AM. |
