Engine Knocking and Engine Flush
RE: Engine Knocking and Engine Flush
ORIGINAL: CandiMan
I think you're refering to pinging (pre-ignition or detonation) Engine knock and engine pinging have two distinctive tones.
ORIGINAL: Landzu
A knock at random when hot sounds like bad gas or low octane or carbon build up try some RXP for the carbon.
Yes thats what I'm talking about,,
ORIGINAL: mellyagaunce
So you think it's carbon build up?
pistons and that will raise the compression just enough to kick in the knock
sensors to stop the knock.
RXP is about $7 so its a good place to start if the noise is still there
after then keep looking.
I always start with the easy things to see if it helps, thats why I
also said to change the plugs.
Good Luck.
wannabe
01-24-2011 10:42 AM
tunernewb92
06-23-2009 04:44 PM
mellyagaunce
10-08-2008 07:55 AM
