RE: Engine Knocking and Engine Flush
The best way I can describe the sound is if you were to wrap one knuckle on a small piece of wood. I just did it and it's only slightly higher in tone than the actual sound the engine is making.
ORIGINAL: CandiMan ORIGINAL: Landzu A knock at random when hot sounds like bad gas or low octane or carbon build up try some RXP for the carbon. Yes thats what I'm talking about,, |
So you think it's carbon build up?
It shouldnt be that much carbon with those miles and the carbon cutter valves.
Take a small hammer and crawl under the truck and tap on the cats. It is rare, but the cats going bad can make it sound like lifter/rod knock. |
ORIGINAL: mellyagaunce So you think it's carbon build up? pistons and that will raise the compression just enough to kick in the knock sensors to stop the knock. RXP is about $7 so its a good place to start if the noise is still there after then keep looking. I always start with the easy things to see if it helps, thats why I also said to change the plugs. Good Luck. |
So where do you buy this RXP?
AutoZone, Pepboys its a 2oz bottle thats orange and will treat 25 gals
I have used it and found that it works, have seen it when doing emissions on a Dyno with the NOX reduced. |
| All times are GMT -5. The time now is 06:58 AM. |
