Engine shut down while driving?
I was pulling away from a stoplight and around 30 mph the engine just shut off like someone turn the key off. I coast in to a gas station that was right beside me and restarted it and everything was fine. No codes, and it started like normal. Its never happened before or since this was a few days ago. Any ideas?
Sounds like the Infamous Crank Position Sensor. That would be my first start. Make sure when you replace it that the spacers go on after you install the spacer then the cover then the bolts.
