Engine shut of at thermostat open??
Just installed the "extinct inline thermostat" w/ 170° thermostat
refill and all good , running engine, taking notes ...
2000 disco 2 ,gas v8
@ 19min20sec - from start
Engine temp 182 ( analog smith's gauge)
". ". Normal ( factory idiot gauge)
Oil pressure 18
Warm air blowing in passenger comp.
engine rpm at idle
Then it just shuts off like I turned the key..
No restart , turns over but no pop. Like fuel or spark is gone..
Let it cool , it will restart and run normal once it sits for many hrs , due to work schedule this time has changed but not less than 12 hrs. I have repeated this 3 times, time changes , oil pressure changes , only constant is temp at which it shuts off ,
Any idea on what I should be looking at ?
Thanks and regards , Roy
Oil pressure 18
engine rpm at idle
Richard Gallant (10-30-2022)
