engine starts up fine then dies out
hey guys i need a second opinion on what wrong with my truck. it starts up just fine but after about 10 seconds its starts choking and eventually just dies out. when i turn it on the revolutions are at about 1250 but the drop down rapidly and hit 100 and eventually the car stalls and dies. if you have any idea please help me out.
edit: when i turn the car on it idles at about 1200 rpm then drops to 100 rpm then before stalling it gets a weird power boost then shoots back up to 1200 then it dies down to 100 rpm and stalls out. any ideas? |
check engine light on? do you have access to a scanner? fuel pressure?
Yea p1300 p0301 p303 p305 p307. Not sure about the fuel pressure
Runs good for about 10-15 seconds then starts to misfire when rpms drop |
check your plugs, wires and ign. coil
does anyone else have any other advice? its strange because my car starts up fine every time but doesn't run more the 20 seconds. new plug wires and plugs but havent changed coil packs
Will is run after the first stalling if you restart it?
Or does it stall every time? How about if you hold your foot on the gas pedal, will it stay running? |
Hey guys I think I've managed to fix my stalling issues. The fix was to reset my throttle and cruise control cables then I cleaned my maf sensor. So next step is getting rid of my new codes. These just came up p1300 p303 p0305 p0300 p0303 p0305. Any suggestions on where to start? I'm about to go fill my truck with gas and add a engine cleaner, any suggestions? Thanks in advance!
I dont know what those codes mean, have you looked them up?
Yea those are misfires. I just cleared them and theyre gone. Now I have p1129 p00134
Bank 1 front O2 sensor wiring is disturbed (open) - no activity seen by ECU.
| All times are GMT -5. The time now is 03:11 AM. |
