Excess Cabine Heat / Electric Cooling Fan Failure?
Old Sep 21, 2015 | 04:15 PM
GURU06's Avatar
Default Excess Cabine Heat / Electric Cooling Fan Failure?
Hello All,
I am trying to track down a source of excess cabin heat on the driver side of a 2004 Discovery.
If the electric cooling fan on the front of the radiator was not working could it cause excess heat buildup that would radiate heat to the inside of the cabin on the driver side?
There is a metal bracket to the right of the gas pedal that gets very hot and a lot of heat builds up in this area - my feet get very hot in shoes! One of the brackets for the drivers side seat also gets very warm.
There also seems to be a lot of heat buildup under the hood - more than usual.
My temperature gauge does not move, I have no codes thrown but the SRS light has now come on which may just be a coincidence.
I replaced my catalytic converters thinking that they may have been plugged even though I had no codes showing before. I thought this may have worked but to no avail.
Any ideas? Anything I should be looking for?
Old Sep 21, 2015 | 07:55 PM
chubbs878's Avatar
Originally Posted by GURU06
Hello All,
Are you going by the stock temperature gauge on the dash, Or do you have an aftermarket installed? With the AC turned on and with the vehicle running and warmed up of course, you can go up to the front of the truck and be able to see and hear the condenser fan running. Is there a heat shield located above the 'cats' that may have bee left off after the replacement? If the motor is running hot you wouldn't feel it in the floorboard. I think you are missing a heat barrier above the cat-converter
Old Sep 22, 2015 | 05:43 AM
drowssap's Avatar
if the condenser fan isnt working i would be more worried about running the engine hot
Old Oct 10, 2017 | 09:04 AM
Guzziguy's Avatar
Hello,
Did you ever find out what was causing the excessive heat on your feet?
I too have a 2004 Disc II and have the same problem.
All the best,
Guzziguy
Old Oct 10, 2017 | 10:03 AM
Sixpack577's Avatar
Originally Posted by Guzziguy
Hello,
All the best,
Guzziguy
As said, could be missing heat shields.
Converters could be stopping up, but that would make engine temp go up.
Basically the cats are right under the driver and front passenger's feet. With a heat shield, aluminum body, and carpet being all that's between them and your feet.
My Disco does not run hot, but the previous owner put an extra set of rubber floor mats under the stock mats. It makes a noticeable difference.
I will be putting a radiant barrier under the carpet (and above headliner) after I fix a few other things. That will fix the heat problems permanantly
Old Oct 10, 2017 | 12:30 PM
Friday Night Disco's Avatar
I have the same issue, however, I believe it is due to my own cheapness...
Let me explain, I replaced the heater core with a cheap brand from China. After doing this, I noticed a fair amount of heat coming from the back side of the heater core closest to my right foot. This only occurs when in ECON mode and when the unit is blowing ambient air.
My fix, that is on the backlog, take some kind of heat blocking fabric and stuff between the center console and drivers side heater core.
Not sure if this is the same issue that you are having but, wanted to highlight you are not the only one and it could be multiple issues.
Also note, my truck likes to run around 201 F
Old Oct 11, 2017 | 01:47 AM
No Doubt's Avatar
Good ideas above, but also an exhaust hole could be blowing hot exhaust up against your floorboard.
Old Oct 16, 2017 | 09:47 PM
LandBeard's Avatar
Try this:
Turn on AC and set temperature to ice cold and the blower to max. Let run for 10 seconds then turn off. Check to see if you still experience the excess heat.
I’ll look for the thread where I read this but it saved my roasting feet.
Old Oct 16, 2017 | 09:49 PM
Sixpack577's Avatar
Originally Posted by LandBeard
Try this:
The AC in my 04 throws ice cubes, it's freezing cold.
There is also noticeable heat from the floor and roof in summer. A radiant barrier will fix that.
Old Oct 17, 2017 | 09:09 AM
Motorhead1's Avatar
I have to use the climate control to have cooler ventilated air instead of heat when on road trips. Even in cooler weather...These rigs heat and cool pretty good.
CANAMDiscovery
Jan 25, 2013 07:22 AM
sickws6
Dec 8, 2011 04:52 AM
01d2Jeff
Oct 18, 2011 08:23 PM
vonfonk
May 6, 2006 06:50 PM
ollie
Jun 2, 2005 02:42 AM
