Factory Side Runner Bolts
I took the side runners (side step) off my old D2 before selling it and want to reinstall them on a new D2 I bought, but can't find the distance/spacer bolts that fit them to the frame. Anyone know where I can find them?
I included a picture of them for reference.
I was faced with this issue many, many years ago when the male end of one on my truck sheared off. I was fortunate to buy one from a salvage source, but as Alex_M suggests, I looked into making a substitute using some threaded rod and some nuts.
The challenge, of course, is replicating the female end of the piece which is not shown in the drawings. A standard-size nut isn't deep enough, but a coupling nut like the one linked below should work.
Luckily, if I recall correctly, the threads are 3/8 x 16. Just cut some 3/8 x 16 threaded rod and run a couple of these plus whatever regular nuts are needed to get it to the required length.
If I'm not recalling the thread pitch correctly you may be able to find metric equivalents, or probably better yet, replace the bolt at the top end onto which the piece threads.
https://www.lowes.com/pd/Hillman-2-Count-0-375-in-Zinc-Plated-Standard-SAE-Regular-Nut/3013470
danyboyGA (04-19-2022)
