Fan clutch
Is there any better or upgrades to the cooling fan clutch assembly or is the oem version from Amazon rock auto or Atlantic British good enough ? |
Dorman 620-112 fan blade or OEM 99-02 fan blade (Dorman unit cost nearly 2-3 times less), then the Hayden 2991 fan clutch. |
1 Attachment(s)
Yep, this^
1-800-BEST-4X4 for all your Land Rover questions, lol |
You can get both parts cheap in Canada too
Originally Posted by Best4x4
(Post 660171)
Dorman 620-112 fan blade or OEM 99-02 fan blade (Dorman unit cost nearly 2-3 times less), then the Hayden 2991 fan clutch. are these noticeable better than the 03-04 ? |
Originally Posted by redwhitekat
(Post 660225)
03-04 is a one piece unit so the Dorman blade & hayden fan clutch blow the OEM unit out of the water in price for sure. Around 75.00 total vs 299.00, then you can choose a HD to severe fan clutch. Not to mention you can now get the parts separately if one or the other had an issue vs the entire assembly. |
You need 4 bolts, washers, (lock washers or loc-tite) for the new fan to the clutch(I forget what size they are, sorry), as the stock assembly is one piece, so no bolts to re-use.
(Post 660171)
Dorman 620-112 fan blade or OEM 99-02 fan blade (Dorman unit cost nearly 2-3 times less), then the Hayden 2991 fan clutch. Also, you can adjust the temp on many fan clutches so that they come on earlier to keep the motor a little cooler, if desired: |
The last fan clutch I grabbed at Auto Zone actually had new bolts with it. |
