fault code 0441
Can anyone help me with this code?
Thanks! |
RE: fault code 0441
P0441 Generic Evaporative Emission System Incorrect Purge Flow Check your gas cap, Then check your vacuum lines. |
Medium rough idle with P0441
So since getting the P0441 code around March of this year. Replaced purge valve with new (Bosch). Cleaned maf and IACV. Also had my mechanic change all plugs, wires, and both coil packs. The code has recently come back and he’s doing a smoke test on it tomorrow. Could the P0441 be causing the rougher idle? I will say it’s worse after driving a couple miles and sitting in gear at a red light. Anybody have any idea what else could be causing the rough idle???
| All times are GMT -5. The time now is 03:57 AM. |
