Originally Posted by drowssap
(Post 515264)
if your ecu sees less than 13 volts the transmission goes into safe mode.
yes; start with a fresh charge battery and check your charging system. also check and clean all the ground cable while you under there, they are another cause. hopefully it will be that simple Put a new battery in and it started back up no problem, thanks |
Originally Posted by Disco Mike
(Post 114172)
Chris, do your self a favor, do not remove your factory cable ends, clean them, tighten them up then go get a free battery/alternator test done at your local auto parts store, get back to us with the voltage with the engine off and at idle, I have seen brand new batteries that fail.
Great work!
Welcome to the forum. |
