Anyone ever used Royal Purple in their Engine?
You got that right...
You got that right...$10.00 a quart...i used mobile 10 /40 full syn and mine still grenaded in about 30 seconds.... You might as well keep it clean ....protection my ***... its a LR..... $200.00 quart cant stop the enevable......
Haha, i put RP in my disco for sh*&s, my friend had 4 extra quarts of 5w30, so i bought a few more and put it in. I had a light engine tick at start up that went away when warm, that has seemed to go away or at least lessen. Other than that, no major difference. MPG seems to be a few better.
Over 3000 miles you use 250 gallons of gas at 12MPG, at 14mpg, you only use 214. Times that by 3 dollars a gallon and by saving 36 gallons you are saving 108 dollars. So if you believe that RP can even save you 2mpg, you will actually save money even if it is 10 per quart. If you dont believe that it saves MPG, then i suppose you wont be convinced.
I just cannot afford that.
Even if it were to save me $28.
