Floor jack question
Just a quick one. Can a 2 ton floor jack use to elevate the 04 Disco so I can put jack stands?
I understand the Disco is about 6000 lbs, but just jacking the front differentials and placing the jack stands? |
I don't know I use 3 ton (per pair) jacks though. They are only like $30.
Yes, go for it.
Yes it will work, you are only holding part of the weight of the truck.
your truck weighs 4700 #'s and a 2 ton will do the job.
My 3 ton floor jack lift the front end of my 7500 pound Dodge with no problem so a 2 ton will work for a Disco.
Alrighty:)
Now the next question, where can I place the jack stand? |
Under the axle will work. (That's not the first answer that came to mind.) What is it you are trying to accomplish.
I was gonna say Under the Axle , too... wasnt 100% sure thats why I didnt
Either under the axle or the frame, depends on how high the truck needs to be and what you are doing, for brakes, under the axle.
| All times are GMT -5. The time now is 12:21 AM. |
