That's That's pretty cool little jack.
I was actually hoping you'd found one that would work as a mobile jack... mine is lifted and the one time I had a flat I had to forage for wood to change the tire with my extra length HF jack. That was no fun. |
My old harbor freight jack finally died after a few years. My only complaint is I ran into issues where it just didn't have enough lift height! Unfortunately, I can't remember how high it would lift.
So, I am looking for a new jack, but the 3 to 4 ton jacks I have found all lift under 20", Which might be enough. You can get one that goes over 20", but I'm not spending $300+ Then I ran across this Arcan Floor Jack. 24" lift is nice, but its only 2 Tons. I know our trucks are only about 4800 pounds fully loaded, but will 2 Tons really be heavy duty enough to lift the truck one end at a time to get on stands without pushing its limits? And to be completely transparent, I like the fact that is low profile so it will go under my Bimmer! __________________ '03 Disco II White Gold Cannibal V8 with performance cam, oil cooler, 180 Tstat 2" Terrafirma Lift, Terrafirma HD Drag Link and Track Rods, D1 Retainer Plate on Rear BFGoodrich 265/75r16 All Terrain KO2s, AB Stainless Brake Lines '04 Disco II Giverny Green Next Project! '13 LR4 Ipanema Sand with Extend Windsor Arabica Leather "She that must be obeyed" pavement princess! '07 LR3 Sliver and Stock, for now. |
So, I am looking for a new jack, but the 3 to 4 ton jacks I have found all lift under 20", Which might be enough. You can get one that goes over 20", but I'm not spending $300+ Then I ran across this Arcan Floor Jack. 24" lift is nice, but its only 2 Tons. I know our trucks are only about 4800 pounds fully loaded, but will 2 Tons really be heavy duty enough to lift the truck one end at a time to get on stands without pushing its limits? And to be completely transparent, I like the fact that is low profile so it will go under my Bimmer! __________________ '03 Disco II White Gold Cannibal V8 with performance cam, oil cooler, 180 Tstat 2" Terrafirma Lift, Terrafirma HD Drag Link and Track Rods, D1 Retainer Plate on Rear BFGoodrich 265/75r16 All Terrain KO2s, AB Stainless Brake Lines '04 Disco II Giverny Green Next Project! '13 LR4 Ipanema Sand with Extend Windsor Arabica Leather "She that must be obeyed" pavement princess! '07 LR3 blue and Stock, for now. |
arcon floor jack
| All times are GMT -5. The time now is 01:36 AM. |
