fluid drops on bottom of front shock
I need help finding my mysterious fluid leak. I've started to notice a few drops of fluid under my front shock in the morning and I can't tell where it is coming from.
The only place I can see a drop of fluid is the bottom of my front drivers side shock. I have cleaned it up but still can't seem to tell where the leak is coming from. My PS and Break fluids are still full and never seem to lose anything. I ordered new SS brake lines in case I have a pin hole leak in one of the rubber hoses but there is no sign they are leaking yet.
Is it possible the actual shock could be leaking?
This might be the excuse I need to finally buy one of them fancy UV kits. I love new tools If I can't find the leak when I install the new brake lines I might just have to try that.
Speaking of break lines. This is off topic but I ordered the Goodridge break lines and I'm pretty sure they only come with 4 lines. I know the AB kit has 6. Do you know of a good place to get the other 2 lines in SS?
I haven't installed them yet and was wondering the same thing about the short ones in SS or if the short ones really need to be SS.
Yep, it's been in my cabinet for about a year so, probably not much I can do about it now.
I thought I looked into it right after I bought it and someone said that the picture shows all 6 but they only come with 4.
Probably is supposed to include all 6 since that's what the pic shows. I was super busy at the time and forgot I even had em for probably 6 months.
That sucks! You bought this kit and it only came with 4?
Performance Stainless Steel Brake Hose Kit - Raised Suspension (ABP218L Same Fit As Part # ABP218L ) - Land Rover kits from Atlantic British
I think you should call or email them about that. The picture clearly shows all 6 brake hoses.
I found this hose on AB and I think it is the SS hose we are looking for but they are $40 each. I think this same hose works for both so that would be $80 to get those 2 little hoses in SS? That doesn't seem right.
Brake Flex Hose Connects Between Modulator And Pipe (SHB101350SS Same Fit As Part # SHB101350 ) - Land Rover hoses from Atlantic British
A new rubber hose is only $18 each, but I would really like for all of the rubber lines to be converted to SS. I looks like I might have to break down and pay the $80.
Brake Hose - Modulator To Rear - Land Rover hoses from Atlantic British
TF also sell a stainless hose kit which is probably made by Goodridge as well.
I installed a Terrafirma SS extended lines. The kit only had the 4 caliper lines. I got the two SS jump lines made for around $60. I will try to go back and see who made them. It was someplace in CA.
edit: http://www.crownperformance.com/land...rake-line-kit/
I had to call them to get a $$ and order it. Then don't have the two jump lines listed.
The price for those is ridiculous. I bought my set of 4 Goodridge for £29.95 or around $50. RN sell the two short hoses that run along the chassis leg try them. I'm informed they are a bit of a PITA to change, don't know whether that's true.
Maybe that's why they were on sale. hehe!
More than likely the shock is leaking. It normally only leaks a very small amount just enough to put a small smattering of fluid amongst the dirt and dust. However, once they are leaking there's sweet FA can be done with them unless they are seriously upmarket Koni's or Bilsteins and more to the point they progessively cease to operate due to pressure losses. There is only a couple of ways to check them out, one is to remove it and inspect and the other is to tie a 'tell tale' bandage around the shock body and then see whether it is damp from oil after a few days.
My '03 seems to sit about 1/2" to 3/4" lower in the front on the right than on the left side, measuring from the top of the tire to the fender flare. I don't see a leak, but this could've happened prior to my purchase. Is this most likely a bad shock, or could it be something else?
It does have ACE, but I didn't think that had anything to do with what I'm seeing.
