-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Fluid leak (https://landroverforums.com/forum/discovery-ii-18/fluid-leak-57801/)
lawsuit larry Mar 23, 2013 08:10 AM
Fluid leak
Bought a 2002 disco six months ago, ( love it) but it has a slight leak somewhere. I add coolant about every two to three weeks. Any ideas? I can smell it but can't see it and the temp guage doesn't go up.
SDinDS Mar 23, 2013 10:02 AM
Did you check the two small hoses going to the throttle body heater plate?
blackhills Mar 23, 2013 10:32 AM
mine leaked there too on the throttle body heater just buy the gasket for 2$ don't buy the kit it felt like a waste of money. be careful of the vacuum tubing i don't know what kind of plastic they made it from but its brittle really brittle
Disco Mike Mar 23, 2013 11:53 AM
If it is not the heater plate, then do a coolant pressure test to find and fix the leak. Let us know what you find.
Jared9220 Mar 23, 2013 03:22 PM
1)Worst case is head gasket is starting to go.
2)throttle body heater is common
3)I had a small leak from one of the screws on top of the radiator. It's under the plastic cover so it's hard to notice. Here is a picture.
https://landroverforums.com/forum/at...r-100_2238-jpg
Happy hunting:cool:
