fluid type?
im changing all my fluids out before a cross-country road trip this weekend.
im trying to run all synthetic reccomendations? tranny fluid? diff fluid? im already running mobil 1 engine oil but its due for a change. is transfer case sealed or not? filters: oil? tranny? 2000 disco II w/135k |
RE: fluid type?
Tranny-Dexron IID
Transfer case and both diffs 85w-140 Any trans filter kit. Any good brand oil filter. The t-case has a drain and fill plug, drain plug on the bottom and fill plug is 3/4 of the way up, on the back of the t-case next to the parking brake drum. Buy a cheap fluid hand pump, it will make refilling your diffs, t-case and tranny easier. Any major brand of full synthetic will do, you will need 2qts for each diff and 3 for the t-case. |
RE: fluid type?
Ditto except for 75W90 in both the diffs and transfer case (Montana winters). Any reputable synthetic that happens to be on sale. 1.8qts in the diffs, 2.2 qts in the T-case. The diffs have magnets in the drain plugs that need to be wiped clean with a paper towel.
RE: fluid type?
Some of the things Rover thought of makes you wonder why all cars don't have them. Magnetic drain plugs - GENIUS!! Such a simple thing that other car companies never even think about.
RE: fluid type?
My Montero had them.
The import companies think about this stuff, drain/fill plugs on the diffs, the domestics you need to remove the cover to the diff, what a PIA. |
