-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Fob trashed needed EKA code (https://landroverforums.com/forum/discovery-ii-18/fob-trashed-needed-eka-code-56495/)
edwhittle Feb 5, 2013 08:20 AM
My fob on the key disintegrated last week and was 5 days without my truck. Tried the generic 1515 EKA code and that didn't work. I live in Panama and the LR dealer is 350 KM away. Finally got someone in the dealer that spoke English to give me the correct EKA code. The code is a four number code (not four digit code) Tried the code with the procedures listed here on the forum all day Friday. No good. I found the workshop manual in the forum and tried that procedure. That worked. So here is the correct way to enter the EKA for remobilization.
""The code is recorded on the security information card and is entered as follows:
1.Using the key,turn the driver's door lock to the UNLOCK position and hold in this position for at least 5 seconds.
An audible warning is then emitted to indicate that the body control unit is ready to accept the code. Return the key to the centre position. It is now possible to use the key to enter the separate numerical values of the four digits that make up the EKA code.
2 Enter the first digit of the code. If the first digit is 4, turn the key to the UNLOCK position 4 times. Ensure the key is fully returned to the centre position after each turn of the key.
3 Enter the second digit of the code. If the second digit is 3, turn the key to the LOCK position 3 times. Ensure the key is fully returned to the centre position after each turn of the key.
4 Enter the third digit of the code. If the third digit is 2, turn the key to the UNLOCK position twice. Ensure the key is fully returned to the centre position after each turn of the key.
5 Enter the fourth digit of the code. If the fourth digit is 1, turn the key to the LOCK position once. Ensure the key is fully returned to the centre position after each turn of the key.
6 Finally, turn the key to the UNLOCK position and back to the centre position, a double bleep will indicate that the code has been entered correctly. A single bleep indicates that the code has been entered incorrectly.
Then, before opening the door, wait 5 minutes for the alarm and immobiliser to be de-activated. During the 5 minute wait for the alarm and immobiliser to be de-activated, the alarm indicator LED in the instrument pack continues to flash (one flash every 2 seconds). DO NOT OPEN THE DOOR OR ATTEMPT TO ENTER THE CAR until the full delay period has elapsed.
When the 5 minute wait has elapsed, the alarm indicator LED stops flashing. Immediately open the door, insert the key in the ignition switch and turn the switch to position II. If the ignition switch is not turned to position II within 30 seconds of the end of the 5 minute wait, the engine is automatically immobilised again.
The EKA code will not be recognised if there is an interval of 10 seconds or more between key turns or if the key is held turned for 5 seconds or more during the procedure.
In some system configurations a successful EKA code entry is indicated by the audible warning device pulsing twice for a period of 50 ms on, 200 ms off. The theft deterrent LED is switched on for 1 second, all doors unlock, the alarm disarms and the vehicle is remobilised allowing the engine to start.
If an incorrect code is entered, an audible warning is emitted and the procedure must be repeated. Up to a maximum of 10 attempts to enter the code is possible. After 10 attempts, the BCU will not allow any further codes to be entered for a period of 10 minutes.""
Other forum posts had me turn the key clockwise 4 times to the left to start the procedure. That didn't work. The one listed above does.
So what I learned after 5 days. Get the right EKA code. I also used
MG & Rover Code Service. EKA | RADIO | KEY. Online or Telephone 01379 669375. to verify that the dealer gave me the right one.
Use the right procedure exactly. One miss turn and it doesn't work.
jafir Feb 5, 2013 08:48 AM
yeah, I posted these instructions to one of the posts that in the stickies at the top of the D2 forum: https://landroverforums.com/forum/di...d-works-45005/
Also, the 1515 code works for US/Canada, but probably not most others. Oddly enough when I connect my computer, there appears to be another EKA on my 2003. I haven't tried either one on that car.
