Fog Lights
I own a 2002 Disco SD, which as you may know doesnt have front fog lights. My truck is white gold with black trim, which means the front bumper is black as well. I've noticed that 2002's with the fog lights that the front bumper matches the color of the car which in my case would be white gold. I want to add fog lights to my truck but keep the black trim. Do I need LR to install them which in that case i beleive the black bumper would change to the white gold, or can i install fog lights myself with the current front end that i have which is black and would like to keep? Any help would be great.
RE: Fog Lights
You can install lights into your front bumper, you should be able to find the wires for the fog light switch tucked in somewhere up and behind your bumper.
Mike |
RE: Fog Lights
So the opening in the bumper that is currently on my Disco is the right size for fog lights? And the switch inside that is for the rear fog lights will operate both the front and rear when i hook them up?
RE: Fog Lights
My Disco has the fog lights with the black bumper. The ex-owner had smashed his original bumper and replaced it with an unpainted black one for the reason that paint wouldn't chip due to road debris. http://images.photomania.com/111941/1/~rad87FD9.jpg
RE: Fog Lights
There should be 2 plank switches, one for the front and one for the rear.
Mike |
RE: Fog Lights
The front bumper on my disco is slightly different. Where the fog lights would be doesnt have a wide opening. The opening is maybe half the size of the fog light.
[IMG]local://upfiles/6205/103CB21457D14EA8B0CD33A77A00B061.jpg[/IMG] |
RE: Fog Lights
I think that this surrounding can be pulled off and replaced with the one that accepts fog lights.
RE: Fog Lights
I would prefer not to pull; the existing surrounding off. Is there any way i can fit smaller fog lights into the current opening and not the usual Land Rover Fog lights?
