-   Discovery II (https://landroverforums.com/forum/discovery-ii-18/)
-   -   Found a test for SAI pump please help me (https://landroverforums.com/forum/discovery-ii-18/found-test-sai-pump-please-help-me-26932/)
isofast Nov 15, 2009 05:30 PM
Hi group I found a test in the shop manual but I am unsure of which is terminal 87 or 30 and which relay and fuse is SAI Pump? Here is test it is kind of cool because you can hear just your SAI pump run on its own without the added engine noise.
The ECM checks the engine coolant temperature when the engine is started in addition to checking the elapsed time
since the last engine start. The engine coolant temperature must be below 55°C (131°F) and the ambient temperature
above 8°C (46°F) for the SAI pump to run. Also, depending on the long term 'modelled' ambient temperature
determined by the ECM, the minimum time elapsed required since the last engine start can be up to 8.25 hours. The
period of time that the SAI pump runs for depends on the starting temperature of the engine and varies from
approximately 95 seconds for a start at 8°C (46°F) to 30 seconds for a start at 55°C (131°F).
With a warm engine which is switched off and the SAI pump relay removed, the SAI pump can be supplied with power
by bridging terminals 87 and 30 at the relay socket.
CAUTION: Ensure that terminals 87 and 87a are not connected or bridged in any way, a short circuit will
occur.
NOTE: TestBook/T4 can also be used to force the SAI system to perform an SAI active diagnostic routine. During this
routine the SAI pump will run for approximately 10 seconds.
When the terminals are bridged or the diagnostic routine initiated, the pump must run when requested which will be
noticeable by the running noise of the pump. Only allow the SAI pump to run for a maximum of 90 seconds and allow
sufficient time for the pump to cool down before running again.
If the SAI pump does not run or makes a scraping noise, it must be replaced. In this case, all other system components
must also be checked.
isofast Nov 17, 2009 03:06 AM
Comments?
Hello anyone?
JUKE179r Aug 24, 2020 09:48 AM
For anyone else in the future looking to jump the relay to test out the SAI pump, it's R6 in the engine compartment fuse box.
In the RAVE manual it shows R6 as the glow plugs relay for a Diesel.
